Home » Audio » Craftsmen » T-nuts, their care and feeding
Re: T-nuts, their care and feeding [message #29881 is a reply to message #29880] Sun, 11 February 2007 10:23 Go to previous messageGo to previous message
Lon,
Just to reiterate the advise from before, you CANNOT use t-nuts on both sides of the panel, only on the back side. Assuming that you hammered down both t-nuts, when you insert the bolts, it will probably not engage the threads on the rear t-nut properly and cause either the front, the back or both t-nuts to lift. If you did not set the t-nuts before inserting the bolt, neither t-nut will draw down.
Again, ONLY ONE T-NUT PER HOLE!!!
Bob
Previous Topic: Need to find a cabinet refinisher
Next Topic: Nostalgic DIYers
Current Time: Mon Nov 30 12:17:29 CST 2026
