Home » Audio » Craftsmen » T-nuts, their care and feeding
Re: T-nuts, their care and feeding [message #29880 is a reply to message #29876] Sat, 10 February 2007 16:05 Go to previous messageGo to previous message
lon is currently offline  lon
Wasn't back in here for a while.
Yes, I have the stuff to countersink and have done that for a tnut
but ran into the backing out probelm using one forward and one
backward. These would not draw down.
A fender washer has nothing on it to give a flush mount.
I would use those socket things made of plastic but I had a bad
experience with them. One time I had a set of kit speakers
and the the holes must have been drilled incorrectly and those
plastic inserts did not fit properly. So I wanted to use a
surface technique to avoid the headaches.
Previous Topic: Need to find a cabinet refinisher
Next Topic: Nostalgic DIYers
Current Time: Mon Nov 30 12:17:06 CST 2026
