Home » Audio » Craftsmen » T-nuts, their care and feeding
T-nuts, their care and feeding [message #29868] Thu, 25 January 2007 12:40 Go to previous message
lon is currently offline  lon
What is it about t-nuts that I don't understand?
I'm doing a build and usinf t-nuts for the first time because I
want a removable back and front for not only interior adjustments but
also possible replacement panels with a port cut in.
I have these things from Parts Express called Hurricane nuts.
The goal was to have these things in pairs on the frame and on the
removable back.
I got my corrent jole size drilled through both pieces and when I
got the t-nuts inserted and tried to screm them down they backed up
and loosened a joint. The joint is a small problem to fix and I'm working on the back to catch any of these mistakes before doing
the front.
In playing with the bolt and the t-nut, there seemed to be a stop
at the end of the nut in the machining.
I want the t-nut on the surface of the removable panel to use as
a magnet catch for a grille on the front side and a mated nut on the
frame to draw down around a seal on the frame that I'll fabricate.
This means that I was figuring on one bolt going through the first and the second drawing down tight to the frame.
Where has the logic or selection of parts gone wrong here?
Previous Topic: Need to find a cabinet refinisher
Next Topic: Nostalgic DIYers
Current Time: Mon Nov 30 12:17:10 CST 2026
