Home » Audio » Craftsmen » Filler for mitered edges that aren't flush?
Re: Filler for mitered edges that aren't flush? [message #29823 is a reply to message #29820] Mon, 23 October 2006 10:34 Go to previous message
gfederys is currently offline  gfederys
I like mixing some fine sawdust from the wood with a 2 part hobby poxy. A drop from each ought to do it. You could even use a hair dryer to get it to flow into the cracks. Mix it so it's pretty thick. 2 things, don't over do it with the hairdryer and "cook" it, sometimes the "fill" will be darker then the wood, test on scrap first to see if it's right for you.
Previous Topic: An uncraftsman question-- Cabinet grade plywood
Next Topic: Guess I'll have to build another base for the amp
Current Time: Sun Oct 25 03:03:08 CDT 2026
