Home » Audio » Craftsmen » Hand drill has a stuck chuck
Re: Hand drill has a stuck chuck [message #29815 is a reply to message #29814] Tue, 17 October 2006 11:24 Go to previous messageGo to previous message
gfederys is currently offline  gfederys
If you're behind the drill, like you're drilling something, the drill motor screws into the chuck, (turns to the right). So you want to put the chuck key on the right side of the chuck, (you're still behind it) and rap it fast and hard, in a downward motion, with a dead shot hammer. If it comes off, put a spot of anti-seize grease on the threads before assembling in case you want to take it apart again. I have several drill guides and 2 different size chucks and take the chuck off of my Makita all the time. P/S, I too live in a condo and have built Lowther Fidelio's this past summer. Boy the neighbor's complain, don't they?
Previous Topic: Interconnects
Next Topic: Newbee Tools
Current Time: Fri Nov 06 23:00:10 CST 2026
