Home » Audio » Craftsmen » An uncraftsman question-- Cabinet grade plywood
Re: An uncraftsman question-- Cabinet grade plywood [message #29813 is a reply to message #29812] Tue, 17 October 2006 10:37 Go to previous messageGo to previous message
lon is currently offline  lon
Thanks for the replies.
I just figured that cabinet grade (cheapo stuff from
HD might have less of the annoying "there's some
plywood" figuring in the panels.
One thing I found that should be more stable is
those glued up panels at Menards (in the Midwest USA).
They look like butcher block so I suppose it depends on
how dutchy your decor is.
Previous Topic: "Whatever the question: Tri-Flow is the answer."
Next Topic: Filler for mitered edges that aren't flush?
Current Time: Thu Nov 12 21:37:08 CST 2026
