Home » Audio » Craftsmen » Hand drill has a stuck chuck
Re: Hand drill has a stuck chuck [message #29809 is a reply to message #29806] Mon, 16 October 2006 13:40 Go to previous messageGo to previous message
gfederys is currently offline  gfederys
Open the chuck as wide as it'll go and look down inside. Some of the older drills had a set screw you had to remove first before the tapping trick will work. If no set screw, clamp it tightly in a vise, really whack chuck key with dead blow hammer, look up "Power Tools, New" in a search engine.
Previous Topic: Interconnects
Next Topic: Newbee Tools
Current Time: Fri Nov 06 23:00:07 CST 2026
