Home » Audio » Craftsmen » Damar + ?? to lacquer African Mahogany ?
Thanks Bill [message #29773 is a reply to message #29772] Tue, 29 August 2006 20:26 Go to previous message
Riot is currently offline  Riot
Thanks Bill for the input. From what I could find on the web, damar is dissolved in 100% pure gum turpentine. Apparently, it takes a few days to fully dissolve. I read one way to do this is add 1 part crystals to 1 part turpentine. You end up with a solution that is thicker than what you'd use, but then you thin it with add'l turpentine to the desired consistency. I'll try it and report back.
Previous Topic: Double Half-Caf Extra Hot Dry Grande Speakers?
Next Topic: Hey Colin!
Current Time: Tue Nov 03 09:05:36 CST 2026
