Home » Audio » Craftsmen » Finish for Purpleheart
Re: Finish for Purpleheart [message #29716 is a reply to message #29714] Tue, 10 January 2006 16:12 Go to previous messageGo to previous message
Most lumber yards will dress lumber (plane and joint) at $50-$60/hr, with mininum charge in place. Price can be higher if you didn't buy the wood from them. There may be a surcharge for your purpleheart if they consider it an "abrasive" material. Purpleheart is great at dulling blades. Should take less than 1/2 hour to dress your two planks, but consider the up-charges.
If you have the muscle, you can dress the planks by hand with a scrub plane, #4 smoothing plane, and #6 or 7 jointer plane.
Do some research before deciding on a finish. Purpleheart can take a colour from magenta-red to purple to greyish brown, depending on finish and exposure to light/air. Start with the link below.
gar.
Previous Topic: Bonding metal to wood
Next Topic: soapstone
Current Time: Wed Nov 04 01:14:37 CST 2026
