Home » Audio » Craftsmen » Conical horn project
Re: Conical horn project [message #29712 is a reply to message #29711] Sun, 01 January 2006 03:09 Go to previous messageGo to previous message
Mount the router to a piece of plywood or MDF for a temp router table. Cut a jig with the 22.5 angle large enough to be stable as it moves along the table. Use double-face tape to hold the workpiece to the jig. Yup. It really works!
SAme can be done with the tablesaw up against the rip fence or build a cross-cut sled.
Previous Topic: So you want some expensive cone feet?
Next Topic: Bonding metal to wood
Current Time: Thu Nov 26 09:34:28 CST 2026
