Home » Audio » Craftsmen » is there an equivalent PEM nut for wood?
Re: is there an equivalent PEM nut for wood? [message #29697 is a reply to message #29693] Sun, 04 December 2005 09:00 Go to previous messageGo to previous message
MQracing is currently offline  MQracing
Hi Bill:
here is a picture of the chassis that we are prototyping. The wood panels on the left and right will have two holes drilled through them all the way... the bottom panel is 1/4" thick (wood or alum) and the top panel (cover) is 3/8" thick (wood or alum)...
so... we want to bolt in through the bottom cover (so that the hardware is blind) and go through the holes on the two side panels and then fasten down the top panel (blindly) with slight compression.
so... we just need to figure out the best way to get threads into the underside of the top panel if we use wood.
thanks for the McMaster carr reference.... your correct... not an easy site to navigate at all.
cheers and thanks,
msl
Previous Topic: Latest woodworking projects
Next Topic: So you want some expensive cone feet?
Current Time: Thu Nov 26 09:33:03 CST 2026
