Home » Audio » Craftsmen » Tuba18 Sub
Re: Tuba18 Sub [message #29608 is a reply to message #29601] Mon, 12 September 2005 22:37 Go to previous messageGo to previous message
lon is currently offline  lon
GarMan,
I'm glad someone tackled this design.
I got about as far as the the 2 labyrinth panels
and then developed arthritis in my wrists.
The project just sits now.
But I'm curious as to what sort of sound you're getting
with it and what kind of plate amp you will use.
I started the project in MDF and don't have a good place to
work, nor do I have a good dust removal system. Right now
I've only got a couple bucks into the project. After looking
at all the measures, I wound up eyeballing quite a bit.
Bill says that these designs are mostly fitted one piece
at a time. The detail of sliding in the panels was an
excellent design concept. Fitz is something else.
So what do you hear?
Previous Topic: Solid State vs Vacuum Tube Finish
Next Topic: sub folded horn
Current Time: Mon Sep 28 17:59:25 CDT 2026
