Audio
Solid State vs Vacuum Tube Finish
Re: Solid State vs Vacuum Tube Finish
message #29598
is a reply to
message #29594
Sat, 10 September 2005 20:51
Bill Martinelli
May 2009
You should give Varnish a try some time.
You can use tung oil and let it cure for a few days, then use 3 coats of varnish. make sure to sand between coats because varnish will not burn in like a lacquer.
Message index
By:
GarMan
on Fri, 09 September 2005 11:49
Re: Amen, Brother Gar, except.....
By:
Bill Epstein
on Fri, 09 September 2005 16:53
I love Wipe-On
By:
GarMan
on Sat, 10 September 2005 17:13
Re: layering poly
By:
Shane
on Sat, 10 September 2005 19:11
By:
Bill Martinelli
on Sat, 10 September 2005 20:51
Only if I can wipe it on
By:
GarMan
on Mon, 12 September 2005 08:21
Re: Only if I can wipe it on
By:
Shane
on Mon, 12 September 2005 21:14
Re: try this.... Wipe on is for martha stewart
By:
Bill Martinelli
on Tue, 13 September 2005 22:13
By:
GarMan
on Wed, 14 September 2005 12:25
PI four enclosure
Tuba18 Sub
Mon Nov 09 18:14:56 CST 2026
