Home » Audio » Craftsmen » Harbor Freight
Re: Harbor Freight [message #29543 is a reply to message #29542] Sun, 03 July 2005 09:53 Go to previous message
I have a couple of Ryobi tools (table saw and router w/table) that are marginal build quality. They are good for the occasional use. This is pretty much the same opinion I have of Harbor Freight, except with HF I know what I'm getting. I have a number of HF tools and they are perfect for the one-time or infrequent use. I bought a drill bit counter sink set and a drum sander attachment from HF that I swear are the same as Rockler sells......Colin
Previous Topic: Another great tool deal
Next Topic: What kind of wood are they using at Walmart?
Current Time: Thu Nov 12 03:17:10 CST 2026
