Home » Audio » Craftsmen » Tung Oil - How to?
Re:Great Post! [message #29453 is a reply to message #29450] Mon, 11 April 2005 19:51 Go to previous message
I find the Lee Valley High Luster tung oil is very thick and sticky right out of the bottle and difficult to get an even and smooth coat. Probably usable with a sprayer, which I don't have. Cut it with some normal stuff and it's a lot easier to spread.
Maybe lacquer-like is not the best term. I got about ten to twelve coats on my 3PI speakers, resulting in a high gloss clear coat thick enough to fill the open grains of the oak panel. Unfortunately it does not have the durability of lacquer.
Recently, at your suggestion, I started playing with boiled linseed oil. Love the stuff. Very different from tung oil.
Previous Topic: Nailgun Advice Solicited
Next Topic: New glue for easy veneering
Current Time: Thu Nov 12 03:27:44 CST 2026
