Home » Audio » Craftsmen » Tung Oil - How to?
Speaking of building boxes... [message #29446 is a reply to message #29445] Sun, 10 April 2005 17:32 Go to previous messageGo to previous message
Eventually I'm going to build a pair of 3 ft^3 sealed subs. I was contemplating that today, and how to build them stiff/dead.
It occured to me that people always use sheet stock and then add braces. Some do the B&W thing and add a honeycomb of sorts to fill and stiffen from the interior.
Has anybody considered emulating a "stress panel" - building a frame out of say 2X2s and then covering the outside/inside with something like 1/2" MDF. I guess the cavities could be filled with Great Stuff or similar (expanding foam). That would result in walls 2-1/4 inches thick - ought to be quite stiff, like a helicopter floor. The baffle would probably be solid, or at least it would be most convienient.
Previous Topic: Nailgun Advice Solicited
Next Topic: New glue for easy veneering
Current Time: Thu Nov 12 03:27:40 CST 2026
