Home » Audio » Craftsmen » It's that time of year............
Re:Biscuit joiners: an answer searching for a question [message #29432 is a reply to message #29431] Thu, 31 March 2005 17:50 Go to previous messageGo to previous message
Are you alternating sides with the clamps, crank on this side, then that side. etc?
Have you tried 3M packing tape instead of clamps? You can get enough pressure pulling on it as you push it down the get a little glue squeeze-out and a good bond.
For pipe clamps try this:
get a 24X36 piece of melamine covered particle board
get a 36" long piece of 2x4 pine
drill 3/4" holes down the exact center of the 2x4 every 6"
Rip the board in half
screw and glue the pieces to the melamine and you will have perfect sized cradles for the clamps every 6" and a surface the glue will easily clean off
Previous Topic: Hard looking joinery made easy
Next Topic: Nailgun Advice Solicited
Current Time: Thu Nov 12 03:15:14 CST 2026
