Home » Audio » Craftsmen » Using Hole Saw w/o Center Bit
Re: Yes that's my Bugle knob [message #29423 is a reply to message #29421] Wed, 16 March 2005 20:57 Go to previous messageGo to previous message
You can have good luck using a hole saw with noe center drill if you pre drill a hole with 'that hole saw' and clamp on the top of the new part you want to drill. The top guide wood should be 1/2 - 3/4 thick and clamped firmly onto the new piece to cut.
A drill press is important for this type of work.
using a hole saw with no center drill is hospital visit waiting to happen!
Bill
Previous Topic: I made the mistake of hooking this up
Next Topic: Need Options for Router Table
Current Time: Sat Nov 07 03:20:33 CST 2026
