Home » Audio » Craftsmen » Jointer and Plywood
Re: Jointer and Plywood [message #29399 is a reply to message #29398] Wed, 02 March 2005 15:10 Go to previous messageGo to previous message
I can't recall ever jointing plywood but why not try?
When you say "pinch" I think you mean the workpiece moves toward and away from the fence a bit? Or do you have an "ear" sticking out on the last 1/2" that goes thru?
The fromer is cured by cutting the first cuts off a large sheet 1/4"+ oversize then flipping the fence edge to be the cut edge and trimming to final length witht eh more manageable=sized piece.
The latter is caused by the weight of the large off'cut falling away from the blade as you flinch a bit on the push through. When you get to the last few inches of the cut be sure and have a hand on each side of the blade pushing on the workpiece side and just following thru on the off-cut side. Despite the large size of either don't push just on the workpiece side. The offcut will always fall away and tear away, leavcing that "ear".
Previous Topic: New Project
Next Topic: The Lynn Sabin Jig: A Great Box Joint Jig
Current Time: Sat Nov 07 03:45:37 CST 2026
