Home » Audio » Craftsmen » Holes in metal w/o chassis punch. HELP!!!
Re: Depends on thickness [message #29383 is a reply to message #29382] Thu, 27 January 2005 03:11 Go to previous messageGo to previous message
If it's very thin you'll need to sandwich it between 2 pieces of plywood and clamp. Thicker sheet means cooling as you drill, a squirt of 3 in one oil. Just use one of those 'bi-metal' hole saws you buy at Lowes/Home Depot. About $10. Be sure and clamp the workpiece to the bench or drill press table. If you don't, the workpiece can easily get away from you and spin.
That's bad!
Better yet, while you're buying the hole saw, see how much a Greenlee punch is over in the electrical dept.
Previous Topic: Magic Eraser cleans metal, too
Next Topic: Plywood Edge Protection
Current Time: Mon Nov 23 00:16:36 CST 2026
