Home » Audio » Craftsmen » Staining problem
Re: Staining problem [message #29376 is a reply to message #29375] Fri, 21 January 2005 10:22 Go to previous messageGo to previous message
ronbrady is currently offline  ronbrady
Hi Bill
I had the same problem with some pine I was working with. I should have used a pre-stain conditioner. I tried using some paint thinner with a rag and then a little stiff brush but all I was able to achieve was to make the higher places blond and the recessed places stayed dark. I think that you might be able to bleach the wood but I have no experience with those chemicals. Sanding will probably just hit the high surfaces and no get the deep penetrated areas without really sanding deep. You might be want to consider staining the other pieces darker to match the dark panel. Next time we will remember to use the pre-stain conditioner.
Best of luck
Ron Brady
Previous Topic: Great News!!!
Next Topic: Magic Eraser cleans metal, too
Current Time: Sun Nov 22 23:49:19 CST 2026
