Home » Audio » Craftsmen » Back to square one, so to speak
Re: Back to square one, so to speak [message #29241 is a reply to message #29237] Mon, 30 August 2004 13:48 Go to previous messageGo to previous message
Again, Check out Harbor Freight (http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=44506) for a pretty inexpensive drill press. If there's one in your area, be sure to sign up on line for discount coupons (5% for $50 and 10% over $100.) Also, I would check out the local paper for deals or garage sales. Drill presses are pretty easy to come by, and I think it would save you a world of frustration......Colin
Previous Topic: Other plywood tricks
Next Topic: No table saw? No problem - build a sawboard
Current Time: Fri Nov 27 06:27:47 CST 2026
