Home » Audio » Craftsmen » Back to square one, so to speak
Re: Back to square one, so to speak [message #29240 is a reply to message #29239] Mon, 30 August 2004 10:48 Go to previous messageGo to previous message
I use holesaws with a drill press whenever possible; they are tricky with hand held drills. With a hand held I use a heavy duty 1/2" drill at 800-1000 RPM with the workpiece clamped to the workbench.
I did use a 1/2" radius quarter round router bit to chamfer the inner side of the mounting holes to allow me to get in there with a tube of silicone sealeant to seal the drivers to the baffle.
Previous Topic: Other plywood tricks
Next Topic: No table saw? No problem - build a sawboard
Current Time: Fri Nov 27 06:27:46 CST 2026
