Home » Audio » Craftsmen » Using a fly cutter
Re: Using a fly cutter ( should be hole saw) [message #29234 is a reply to message #29233] Wed, 25 August 2004 04:57 Go to previous messageGo to previous message
In the hole saws I have (and had), the arbors are removable from the hole saw itself. The bit in the arbor is held in place with a set screw.
I don't see why you can't insert any bit you want to use.
I don't think there's anything particularly special about the bit that comes with the average hole saw, at least the ones (Lenox) that I have.
Previous Topic: Quick poll: what would you veneer with out of these?
Next Topic: Other plywood tricks
Current Time: Thu Nov 26 11:22:55 CST 2026
