Home » Audio » Craftsmen » Using a fly cutter
Using a fly cutter [message #29231] Sat, 21 August 2004 11:05 Go to previous message
lon is currently offline  lon
I just wondered if there's an answer to the question of getting
plug out of a fly cutter-- those hole saws used with a
drill press or power drill.
Only thing I thought of is boring nearly all the way through
then using the drill bit center as a guide on the reverse side,
finishing the cut so the plug doesn't get wedged in the
hole saw.
Coming up on a project for arrays, a hole saw makes the job
both easier and gives a smoother cutout.
Previous Topic: Quick poll: what would you veneer with out of these?
Next Topic: Other plywood tricks
Current Time: Thu Nov 26 11:22:36 CST 2026
