Home » Audio » Craftsmen » Quick poll: what would you veneer with out of these?
Re: JARRAH [message #29223 is a reply to message #29215] Thu, 19 August 2004 17:48 Go to previous message
Adrian,
The 13mm is plenty. For very large horns in the bass range the 19mm would be a better choice. Even then, 13mm is still plenty when you start bracing the structure. Sometimes making joints in the thicker materials can be easier. The thinner material would be just fine.
Bill
Previous Topic: What's the deal with Baltic Birch plywood?
Next Topic: Using a fly cutter
Current Time: Thu Nov 26 11:35:17 CST 2026
