Home » Audio » Craftsmen » Couple of Poly questions
Re: Couple of Poly questions [message #29196 is a reply to message #29195] Sun, 08 August 2004 15:38 Go to previous messageGo to previous message
If the finish is OK you can probably salvage it without going to bare wood. What kind of wood is it and how smooth do you want it? Furniture smooth or Steinway smooth? Simply taking it down with some 220 grit paper to smooth and then spraying on a couple of coats of aerosol poly may be adequate, but for a piano finish it's a lot more work.
Previous Topic: First routing experiences less than rousing
Next Topic: Whats everyone building?
Current Time: Sat Oct 17 05:08:17 CDT 2026
