Home » Audio » Craftsmen » Need help with Polyurathane.
Re: Need help with Polyurathane. [message #29167 is a reply to message #29166] Tue, 20 July 2004 14:11 Go to previous messageGo to previous message
James W. Johnson is currently offline  James W. Johnson
Thank you.
What kind of pads should I buy? I am unable to spray because I dont have the equipment, is there another way of doing it?
I am going to have some serious sanding to do to get back to where I was, I wonder if it would be ok to use a radom orbit sander for this first sanding?
I am not ready for anything more advanced than what you mentioned above.
As far as the finish I am trying to achieve goes..I just want a smooth and clear satin finish that will last for many years.
Previous Topic: Staples Redux
Next Topic: How do you spell Formica?
Current Time: Thu Nov 19 15:57:21 CST 2026
