Home » Audio » Craftsmen » Need help with Polyurathane.
Re: Need help with Polyurathane. [message #29166 is a reply to message #29165] Tue, 20 July 2004 10:06 Go to previous messageGo to previous message
Tell the guy at Lowe's to stick with painting barns. What kind of finish are you trying to achieve? The easiest method with poly is to apply with a pad, sand with 220 grit between coats to keep it smooth and then kiss it with a final coat sprayed on. Start by sanding down what you have with 120 to get a decently smooth base.
More advanced techniques involve wet sanding with superfine grits and then buffing with different grits of rubbing/polishing compounds.
Previous Topic: Staples Redux
Next Topic: How do you spell Formica?
Current Time: Thu Nov 19 15:57:16 CST 2026
