Home » Audio » Craftsmen » How to Flush-mount Irregular Shapes?
Re: How to Flush-mount Irregular Shapes? [message #29152 is a reply to message #29151] Tue, 13 July 2004 16:40 Go to previous messageGo to previous message
Somewhere on either PE or the Full Range Forum someone had a tutorial on doing just that. Search flush mount, I guess. You could also walk into a Woodcraft or Rockler and they would be happy to show you how to use brass collars they'll sell you for your router for your router.Doesn't quite come out in a few words but basically you're cutting a template that is 1/2 diameter of the collar away from the fit of the driver. Once the template is cut you mark it and save it and the routing is a snap.
Previous Topic: Anybody here using the Forrest WW II ?
Next Topic: Staples Redux
Current Time: Sun Nov 22 23:25:24 CST 2026
