Home » Audio » Craftsmen » Finished PI
Re: Porter Cable 690 and some HUEVOS! [message #29104 is a reply to message #29103] Fri, 28 May 2004 00:40 Go to previous messageGo to previous message
lon is currently offline  lon
Ok. This is slightly diffferent ( by my reading) than described
over at full range driver site. I've done the break-in routine on two
pairs of speaks. Method used was putting the speaks face to face and
bolting them together. I checked the polarity by using a
small battery and test leads and hooked up the wires push and
pull respectively. It still makes a good amount of racket.
When doing this procedure it'd be handy to have a small safe
with wire leads drilled in the back. :-)
Previous Topic: Veneering video's
Next Topic: a baffleing question
Current Time: Fri Nov 06 05:44:18 CST 2026
