Home » Audio » Craftsmen » Need advice on painting MDF
Re: Spraying, rolling, brushing? [message #29041 is a reply to message #29040] Sun, 11 April 2004 19:56 Go to previous messageGo to previous message
My experience painting MDF is that once the smooth, "sealed" factory surface is cut or sanded it becomes infinitely porous. No matter how many coats or what paint (spray only) that I used it always showed flatter than the surrounding areas.
Maybe I didn't sand well enough? I don't know, but I don't think that's the problem. It's like painting a roll of toilet paper, end on.
Previous Topic: For Beginners
Next Topic: Nice Sub Design
Current Time: Tue Nov 03 10:21:06 CST 2026
