Home » Audio » Craftsmen » Table saw recommendations?
Wait a minute [message #29004 is a reply to message #29002] Wed, 31 March 2004 06:49 Go to previous messageGo to previous message
Dean Kukral is currently offline  Dean Kukral
I have been thinking about this some more.
Whether the back of the jig is square to the blade or not is irrelevant.
If you want the newly cut edge to be square to the old edge that is resting against the jig's back, then the back of the fence must be square to the track, not to the blade. This is because the jig slides in the track.
If the blade is not parallel to the track, then either it angles away from the cut, which will probably cause a rough edge or maybe even some binding, or it angles into the cut, which would definitely cause binding and would be dangerous.
I am not an experienced craftsman, so I am certainly open to disagreement, but it sure seems to me that if your blade is not parallel to the track, then you have a serious problem.
Previous Topic: Tube PreAmp - Done! (almost)
Next Topic: For Beginners
Current Time: Tue Nov 03 07:52:50 CST 2026
