Home » Audio » Craftsmen » Table saw recommendations?
Re: Table saw recommendations? [message #28992 is a reply to message #28990] Mon, 29 March 2004 07:36 Go to previous messageGo to previous message
Ryder is currently offline  Ryder
Hi:
I am hardly an expert myself and will be intereseted in what some others have to say here.
I think it is quite hard to get what you want unless you stumble onto something used and then tweak it a little. My home brew answers were always slow and a bit awkward. To get really good cuts, without a lot of set up time, you need a steady and large table and steady blade and a square fence. A lot to ask at your price point. My answer was to buy my big pieces from a lumber yard in town that does a lot of custom work. They make the first cuts and bring it down to a size for the project where my smaller table can handle them nicely. This solution was just to easy to bother with anything else. I will never have the table they use. Handling full sheets by yourself on typical home ($500 table) equipment is not easy.
Cheers
Craig Ryder
Previous Topic: Tube PreAmp - Done! (almost)
Next Topic: For Beginners
Current Time: Tue Nov 03 07:50:34 CST 2026
