Home » Audio » Craftsmen » Veneering tips for large boxes
Re: Veneering tips for large boxes [message #28985 is a reply to message #28982] Wed, 24 March 2004 22:04 Go to previous message
lon is currently offline  lon
Glad it was useful to somebody and not widely in use already.
BTW here is the best tip I ever got outside of being a cab
driver:
If you have a screw that has the top worn off and
you can't get it out with a screwdriver do not try to
drill it out first. A method that was passed on to me
was to file one of the screw sides flat and then the
opposite side. This makes it a snap to get the screw
loose and removed with a small pliers or other pinch
tool.
I encountered the initial problem with a 5.25 drive
and couldn't sensibly drill in toward the mechanism.
It's the best tip I know and I wouldn't have thought
of it yet if somebody at alt.fifty-plus.friends didn't
tell me about it. Save and share with my compliments.
Previous Topic: Somebody motivate me
Next Topic: Tube PreAmp - Work in Progress
Current Time: Thu Oct 15 22:30:01 CDT 2026
