Home » Audio » Home Theater » The Power of Nightmares
Re: The Power of Nightmares [message #28812 is a reply to message #28811] Mon, 31 January 2005 00:12 Go to previous messageGo to previous message
There is a difference between PAL and NTSC, so it may not work for you. But MPEG is universal, so you may not have a problem. It depends on what format they've used. In any case, converters and editors are available, so if the file is some sort of format you can't use, you can easily convert it.
There are a lot of other programs like that out there too, so you might look around. I use a hardware converter, which is nice when dealing with composite video. But since yours will be a file, you can probably grab one of these programs as a demo, use it for your conversion, and then let the evaluation period lapse.
Previous Topic: HT system
Next Topic: Paradigm's
Current Time: Sun Nov 08 11:31:29 CST 2026
