Home » Audio » Home Theater » A couple of general Home Theater questions if I may...
Do you have a decoder? [message #28487 is a reply to message #28486] Wed, 23 February 2005 17:56 Go to previous messageGo to previous message
You need some kind of decoer to send the unique signals to each amp. Do you have a 5.1 or 7.1 preamp/decoder? If not these can be picked up pretty cheap at the usual consumer electronic stores. Look for one with pre-outs - this way you can use your own amps. Yamaha makes a really nice one for less than $400 The surround speakers should not make that much of a difference if they are not the same. I would try running w/o center channel just to see if you like it. Believe it or not, there are a lot of people that prefer phantom center.....Colin
Previous Topic: in-wall volume control 1 input into 2 speakers
Next Topic: 'way down deep' Article
Current Time: Sat Oct 31 09:37:56 CDT 2026
