Home » Audio » Home Theater » Cable TV hum
Re: Cable TV hum [message #28475 is a reply to message #28474] Sat, 16 October 2004 21:06 Go to previous messageGo to previous message
Hi Ken,
This is actually very common. In many cases, the cable television shield is at a different potential than earth ground on the wall socket. It would be nice if they connected these together at the point of entry, but many times, they don't. So a ground loop results when you connect your cable to your television and to your sound system.
There's an easy solution if your television (and radio tuner, if connected) has 300 ohm antenna inputs. Get a 75-to-300 ohm transformer and connect the cable through it. This will isolate the cable shield from chassis ground and will break the ground loop and reduce the hum.
Wayne
Previous Topic: Sonotube stuff
Next Topic: Tubed HT system
Current Time: Thu Nov 26 18:04:27 CST 2026
