Home » Audio » Pro Sound » overloading powered speakers
Re: overloading powered speakers [message #28392 is a reply to message #28391] Mon, 30 April 2007 11:30 Go to previous messageGo to previous message
::if the powered speakers are set fairly low (5/10) but the desk is pushed as far as it can go are the speakers in danger?
Yes if you clip anything before the speakers the powered speakers are just going to amplifiy that clipped signal.
::the built in limiters are certainly limiting, but im dont think im hearing distortion... just fairly ugly compression.
You should be, the limiters are doing there job so you don't blow the speakers.
::if i were to drive the desk this hard into a system without limiters would it be more dangerous to the speakers?
Sure your sending clipped waveforms to the speakers, the only thing the amps are going to do is amplifiy the clipped signal.
You definetly need more amps and speakers for metal bands.
HTH
Bill W.
Previous Topic: Using Leslie Cabinets?
Next Topic: 50's Marvel 25 Amp Info Needed
Current Time: Thu Nov 26 19:13:42 CST 2026
