Home » Audio » Pro Sound » Carvin
Re: Carvin [message #28244 is a reply to message #28242] Thu, 26 July 2007 11:02 Go to previous messageGo to previous message
The Carvins just use Eminence drivers in there cabinets, there's not a lot of Carvin users around my area but the guys that do run them seem to be pretty happy with there equipment(electronics). You have to remember the Carvin dual 18 is a reflex box, where as the 12pi is a horn loaded sub. And the 12pi will blow the Carvins out of the water as far as projection and SPL's go at a farther distance. So comparing the two is like comparing apples to oranges. Also make sure in there spec sheet that the 30HZ they claim is not the -10db down point, otherwise the box will only be good to about 40HZ before starting to roll off.
HTH
Bill W.
Previous Topic: Sunfire ?
Next Topic: replacement part for Trace Acoustic amp
Current Time: Sun Nov 29 03:48:17 CST 2026
