Home » Audio » Pro Sound » Prosound Shootout
Re: JBL SRX728S [message #28214 is a reply to message #28212] Thu, 02 November 2006 14:44 Go to previous messageGo to previous message
Each of those charts was done with a 2v signal. Since the distance was 10 meters, add 20dB for the 1m value. Add another 3dB if you want to normalize to 2.83v. The JBL SRX728S response chart shows about 98dB/2v/1M at 100Hz, 97dB at 70Hz and a smidge under 96dB at 50Hz. Peak output is about 106dB at 500Hz, and there's a peak to 104dB at 220Hz. There's a 10dB dip at 200Hz and a 20dB dip at 450Hz.
I think what may be causing some confusion is the way Praxis works. The data captured hasn't been post-processed or anything like that. There is a sense line that reads amplifier voltage and presents the data normalized to a reference level. In each of the datasets captured at this year's Prosound Shootout, the reference level was 2v. This is comparable to last year's 28.3v measurement, but offset by 23dB. There is also a decibel/voltage/power conversion chart posted so that people can compare SPL between systems having different impedance.
Previous Topic: marshall AVT amps
Next Topic: Subwoofer help
Current Time: Thu Nov 26 08:38:33 CST 2026
