Home » Audio » Pro Sound » slot loading for horns?
Re: slot loading for horns? [message #28211 is a reply to message #28208] Thu, 02 November 2006 01:13 Go to previous messageGo to previous message
moray james is currently offline  moray james
Yes that's exactly what I was referring to, the size of the actual throat opening. I'll have a go at flying the horn response program and have a look see at what happens when the throat area is manipulated up and down. Does driver xmax factor into this? Most older drivers had smaller xmax than some of the newer offerings. If you have double the xmax would you need to generate the same compression ratio for a given horn? Regards Moray James.
Previous Topic: Hey Wayne what do you think?
Next Topic: buying my first marshall... need guidance!
Current Time: Wed Oct 21 21:44:16 CDT 2026
