Home » Audio » Pro Sound » Prosound Shootout
Re: Comparison of systems [message #28196 is a reply to message #28194] Wed, 18 October 2006 17:36 Go to previous messageGo to previous message
Doubling impedance cuts current in half, which is equivalent to a 3dB reduction in power. However, impedance of loudspeakers is complex, in that it isn't a flat value like a resistor. What we did last year was to use the minimum impedance to calculate the voltage level that would be needed to produce the desired power level. So we tested last year using fixed power levels rather than fixed voltage levels. The 100 watt power level at 10 meters corresponds exactly to the 1W/1M SPL level. Last year we also measured response at one fixed voltage level, 28.3v, which then gave the 2.83v/1M SPL value since we measured at 10 meters distance.
Previous Topic: marshall AVT amps
Next Topic: Subwoofer help
Current Time: Thu Nov 26 08:38:21 CST 2026
