Home » Audio » Pro Sound » Hornsub shootout
Re: Hornsub shootout RESULTS - DR250 [message #28129 is a reply to message #28128] Mon, 31 October 2005 07:54 Go to previous messageGo to previous message
Leland Crooks is currently offline  Leland Crooks
I think Bill's figures are with an MCM driver. Mine are with a beta 10. Also my tweeter configuration is not optimal. I have too much spacing between the drivers, leading to comb filtering. (Bill's been getting on me about it since I built them ) That accounts for the spikiness in the upper end. The original plans called for 10, which I built from, but closer together. Since then it has been figured out you can go to 14 piezos in the face, which I plan to do pronto. Will smooth all of that out, increase efficiency, and look cool as hell. When I get it done I'll run some tests with my primitive gear and post it. I don't have a $2k rig like we had at the shootout, but should at least give an indication.
It's an amazing box. Sound guys look askance at it until I fire it up. The sound quality from a $40 woofer and $10 worth of piezos is insane. Along with the volume from only a couple hundred watts. Not an easy build.
Previous Topic: Basshorn or Transmission Line
Next Topic: Seymour Duncan 84-50 Reverb
Current Time: Fri Oct 23 05:12:15 CDT 2026
