Home » Audio » Pro Sound » Eminence driver that can handle 1250 wattts RMS, with heat sink
Re: Eminence driver that can handle 1250 wattts RMS, with heat sink [message #28114 is a reply to message #28110] Thu, 20 October 2005 08:38 Go to previous messageGo to previous message
Wouldn't work to good, for one thing the horn cabinet would be massive, another thing it dosen't have the magnetic strength (BL) for good cone control in a long horn, the fs is to high so it would have trouble getting down to 30hz. The Qts is also a little high for horn loading, you want Qts to be like between .2-.4 preferably. It would probably be kick ass in a horn that was designed for 50hz though, but not 30. Try running some models in McBeans and see what you come up with.
HTH
Bill W.
Previous Topic: do karlson do anything well?
Next Topic: "Master" guitar amps
Current Time: Fri Nov 06 06:45:24 CST 2026
