Home » Audio » Pro Sound » Hornsub shootout
Re: Hornsub shootout RESULTS - Tuba 24 [message #28081 is a reply to message #28078] Sat, 15 October 2005 13:20 Go to previous messageGo to previous message
http://prosoundshootout.com/Photos/Tuba24.jpg
Tuba 24 basshorn sub
The Tuba 24 was the first to be tested. It weighs in at about 65 lbs and measures 24" x 24" x 24". It uses a single Eminence HL10A, although this one has a prototype HL10C driver. The difference is the C model is 4 ohms and has a smaller 0.75" cooling vent. Other than that, performance appears to be identical.
Specifications:
Weight: 65lbs
Dimensions: 24" x 24" x 24"
Power handling: 300wrms
Impedance: 6Ω or 12Ω (depending on driver)
Frequency range: 40Hz - 200Hz
Sensitivity: 102dB/W/M
Max Output: 128dB/M
Distortion at 100 watts: 5%
First, we measured impedance and found Zmin to be 6.0Ω. So 24.5v is required for 100 watts, 34.6v for 200 watts, 49v for 400 watts and 60v for 600 watts.
Next, we measured output at 28.28v. This is a little more than 100 watts. Since we measured 10 meters away, the values correspond to 2.83v/1M.
[align=center]http://prosoundshootout.com/Measurements/Tuba24_28v.gif
[b]Tuba 24 response at 10 meters with 28.28v input (2.83v/1M)
From this, we perform an inverse FFT to obtain impulse and step response:
http://prosoundshootout.com/Measurements/Tuba24_Impulse.gif
Tuba 24 Impulse Response
http://prosoundshootout.com/Measurements/Tuba24_Step.gif
Tuba 24 Step Response
Measurement at 100 watts:
http://prosoundshootout.com/Measurements/Tuba24_100watts.gif
Tuba 24 response at 10 meters with 24.5v (100w) input (1W/1M)
The blue line is SPL, and the violet line shows distortion. Average distortion is 25dB under the fundamental, which is about 5%. Since measurement was taken at 10 meters, add 20dB to find SPL at 1 meter. With 100 watts input, the 10 meter measurement works out the same as 1 watt input measured at a distance of 1 meter.
Measurement at 200 watts:
http://prosoundshootout.com/Measurements/Tuba24_200watts.gif
Tuba 24 response at 10 meters with 34.6v (200w) input
Output at 200 watts measured at 10 meters is about 105dB average between 70Hz and 170Hz, which is 125db at 1 meter.
Measurement at 400 watts:
http://prosoundshootout.com/Measurements/Tuba24_400watts.gif
Tuba 24 response at 10 meters with 49v (400w) input
Output at 400 watts measured at 10 meters is about 108dB average between 70Hz and 170Hz, which is 128db at 1 meter.
Measurement at 600 watts:
http://prosoundshootout.com/Measurements/Tuba24_600watts.gif
Tuba 24 response at 10 meters with 60v (600w) input
Increasing power from 400 watts to 600 watts results in little increased acoustic output.
Previous Topic: Basshorn or Transmission Line
Next Topic: Seymour Duncan 84-50 Reverb
Current Time: Fri Oct 23 07:24:40 CDT 2026
