Home » Audio » Pro Sound » Hornsub shootout
Re: General test plan [message #28060 is a reply to message #28059] Mon, 05 September 2005 03:14 Go to previous messageGo to previous message
The test signal for response is actually an MLS (which sounds kind of like pink noise) or swept sine, depending on the measurement system. It is a relatively short burst, so these test signals won't heat up your voice coil very much at all.
The thing to be concerned with is the heat soak signal, but even that isn't going to be run so long that it would likely hurt the voice coil, even at full rated RMS power. If we ran it an hour, then it might though. What we'll be doing is to run at 80% rated power, which in your case is 240Wrms. That will not heat the driver to damaging levels, so it will not harm your driver.
Previous Topic: Basshorn or Transmission Line
Next Topic: Seymour Duncan 84-50 Reverb
Current Time: Fri Oct 23 05:11:44 CDT 2026
