Home » Audio » Pro Sound » Hornsub shootout
General test plan [message #28058 is a reply to message #28057] Sat, 03 September 2005 23:45 Go to previous messageGo to previous message
A general test plan is listed below. The specific details of the test plan are specific to the test platform, which is probably going to be Praxis or LMS. David Lee has graciously offered to provide these test platforms and other assistance.
    1) Impedance sweep, cold.
    2) Impulse response.
    3) Frequency response w/SPL at 1W/1M, 10 Hz to 20 kHz (Measured at distance and corrected to 1M)
    4) Frequency response (20 Hz - 200 Hz) w/SPL at 3dB increments to rated power or physical limits. (This will show heat compression and max SPL)
    5) Distortion at 110dB (20 Hz - 200 Hz) and then at 3dB increments from there to rated power or physical limits. (This will indicate the practical limits of the system regarding usable maximum clean reproduction.)
    6) Run heat soak signal 15 minutes at 80% power, repeat steps 4 and 5.
    7) If required, processors can be applied and tests 2, 3, 4, 5 and 6 repeated.
    8) Single horn tested first, pairs or groups tested next if desired.
    9) Subjective listening test using a selection of identical program material played at a referenced sound level.
    10) Subjective listening test using a selection of identical program material played at the maximum sound level of the loudspeakers.
All measurement will be taken from the same place. To save time and insure the least variation, the microphone will be placed at ground level and not moved. All cabinets will be placed on the same mark at the same distance from the microphone.
Previous Topic: Basshorn or Transmission Line
Next Topic: Seymour Duncan 84-50 Reverb
Current Time: Fri Oct 23 05:11:43 CDT 2026
