Home » Audio » Pro Sound » Folded horns - W verses equiangular spiral
Acoustic Lever [message #28045 is a reply to message #28034] Tue, 03 May 2005 11:04 Go to previous messageGo to previous message
I saw your Acoustic Lever in your book, "Audio Transducers" and it is an interesting concept. But I don't think many people here are familiar with it. Would you care to show a diagram here, and possibly describe how it works?
Your illustration in the book was enough for me to see what you are trying to achieve, and you provided a cursory explanation but you really only dedicated a couple pages to the subject. That may be all that is required to conceptualize it mathematically, but I'd like to see it explored in more detail.
My hunch is that it would be best used in bass subsystems, because of its mass. In that regard, it seems like a relatively small area radiator could be coupled to a much larger radiating lever membrane, on the order of areas similar to a basshorn. That might provide the efficiencies of a horn, but without the peaks from being undersized as basshorns almost always are. It has very intriquing possibilities.
Might be worth asking Eminence to build one, since they are setup to do it. Then again, maybe you can get a better deal through your contacts at B&C. But either way, I'd love to see tests of a few samples made with various size primary and secondary diaphragms.
Previous Topic: Over Dwell the reverb surf pan
Next Topic: Presence control for my guitar
Current Time: Thu Nov 19 08:36:37 CST 2026
