Home » Audio » Pro Sound » Folded horns - W verses equiangular spiral
please reference the tests [message #28026 is a reply to message #28020] Thu, 13 January 2005 07:11 Go to previous messageGo to previous message
"That's bull, a folded horn will always out perform a direct radiator as far as lower distortion and more SPL's go. They just won't go as low in freq as a direct radiator can with out becoming massive. And there's tests out there that will prove it."
I have never seen a real advantage to LF horns - and the disadvantages of internal resonances from the folds, etc. is obvious. Please give a rference to the "tests" that prove your position.
Of course your statement is rather general and ill defined. Do you mean "outperform" in general or that a specific driver in a horn will outperform the same driver direct radiating. Because to the first point, I don't agree at all. I can always find a bigger driver in the same size enclosure as the horn that will produce as much SPL and low distortion as another driver with a horn. To the second point, an Acoustic Lever will always outperform a horn in this regard - higher SPL, lower distortion for a given driver in a given enclosure volume - so give me the lever, not the horn.
Previous Topic: Over Dwell the reverb surf pan
Next Topic: Presence control for my guitar
Current Time: Sun Nov 29 00:51:39 CST 2026
